Discussion topic: 2nd hand Gigafast router
Message posted on 11 Jun 2026 10:04 AM
Hi, would it be possible for me to buy a 2nd hand Gigafast router and pod to replace the provided max hub? As others have said, their wifi range is not great and I can't really afford to upgrade to the Max wifi product and wondered if this would improve the range.
I've only had fibre for 3 weeks.
Message posted on 11 Jun 2026 10:10 AM - last edited: 11 Jun 2026 10:11 AM
Re: 2nd hand Gigafast router
The answer is within this support community https://helpforum.sky.com/t5/Broadband/Replacing-Max-Hub-with-my-own-3rd-party-router/td-p/4863891
Personally I'd go for new.
Message posted on 11 Jun 2026 10:14 AM
Its not worth it, 3rd party options are usually better and cheaper. I would look into a mesh system
Message posted on 11 Jun 2026 10:46 AM
They want £40 for an "as new" gigafast router and 1 pod.
Message posted on 11 Jun 2026 10:53 AM - last edited: 11 Jun 2026 12:02 PM
Unfortunately that equipment wouldn't match what the Sky database shows you as being allocated, which means hardware administration in the My Sky app wouldn't be possible.
Perhaps also note that you'd effectively be purchasing stolen goods, because it would only be on loan to the original user and ownership doesn't transfer even if they've paid a non-return fee.
