Discussion topic: 28th August Internet not connecting
This message was authored by: Phoenixfia
Internet was working a few hours ago without issues, I went down for nap, came back and computer / tv, phone, none connected, keeps trying to connect but never works, seems alot of people in the last couple of hours have lost Internet connection, is there a reason? Service status doesn't show anything, and hub lights haven't changed, nothing indicating an error
Re: 28th August Internet not connecting
@Phoenixfia
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
