Discussion topic: 2 red lights
Message posted on 18 Jan 2026 02:44 PM
2 red lights
The app is saying my WiFi is okay but there's two red lights showing
Message posted on 18 Jan 2026 03:25 PM
Re: 2 red lights
@Sannah
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
