Discussion topic: 2 orange lights on my modem
Message posted on 12 Aug 2025 10:08 PM
Message posted on 13 Aug 2025 05:36 AM
Re: 2 orange lights on my modem
@WendyJayne
If your broadband still isn’t working this morning and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
