Discussion topic: 2.4ghz setup
This message was authored by: Jlync
2.4ghz setup
I have video doorbell that is for 2.4ghz but have skymax hub.How can I make this work?
Re: 2.4ghz setup
@Jlync Read the help below very very carefully and turn off the 5Gh as a short term measure, once you get the doorbell connected turn the 5Ghz back on, you may need to adjust the wpa3-T also down to wpa2-psk mode, if so do that first!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
