Discussion topic: 18Mbps on Ultrafast 1 Fibre Broadband
This message was authored by: LeeMell49
Had Ultrafast 1 full fibre broadband with a contracted 100Mbps minimum download speed.... why an i only getting 18Mbps?
Re: 18Mbps on Ultrafast 1 Fibre Broadband
@LeeMell49
How are you testing it? The 100mbps quoted figure is only guaranteed over ethernet
I am NOT a Sky Employee
Avatar for LeeMell49
Tested using the My Sky app. Guaranteed download speed is 100Mb/s, and Sky app is showing 18Mb/s
So, its there a guaranteed wifi download speed?
@LeeMell49
Could you post your hub stats
This message was authored by: peter-marlow+1966
If you have  Netflix  open the app, go to get help  click on that scroll down to check network  and run a test, see what that tells you
P c marlow
Checked Netflix and getting 7Mb/s
Ring sky, when it  say we have  sent you  a link would  you like to use it say no and you  will  speak to  an advisor
P c marlow
Also tell them how  long it's  been  going on for
P c marlow
Your master phone socket  will  be an open reach  one could  be some sort of break in the phone line, or something  wrong  with  the  socket
P c marlow
