Discussion topic: 16 MBPS
This message was authored by: MarieDigbe
16 MBPS
16 MBPS. The WiFi is so slow
This message was authored by: Me134
Re: 16 MBPS
Presuming the speed to the router is as expected have a look at the following to see if they can resolve your problem easily, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Avatar for MarieDigbe
60MB/s
Hi there,
my Internet is very slow again
my Wi-Fi is 60 MB per second
we need to do something about it
Re: 60MB/s
@MarieDigbe
If the Wi-Fi has become slow see any troubleshooting in this link https://www.sky.com/help/articles/broadband-diagnostic-start
