Discussion topic: İnternet disconnect
Message posted on 07 Jun 2026 07:23 PM
İnternet disconnect
I've been having internet problems since yesterday; the internet disconnects every two hours. When I checked with an app looks no issue but right now the time is 19.23 and no internet
Message posted on 07 Jun 2026 07:26 PM
Re: İnternet disconnect
@Kenan
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
Message posted on 07 Jun 2026 07:35 PM
I have checked the link looks like no problem but still no internet and checked the Hub and internet light is amber not green O do not know what does the mean?
Message posted on 07 Jun 2026 07:39 PM
Did you run this line test:
Message posted on 11 Jun 2026 08:48 AM
yes some one tried to help me but not becapsue everyday during evening hours I am having same problem , the wife is drop for 15 mins and more , last time I got a call from SKY because I am changing my broadband now and asked them I am having an issue and told me your are using old technologhy thats why you are having some problem,
