This discussion topic is read only Discussion topic: update sky plus to wifi
This message was authored by: kittykaycat
Hi,  Im trying to stream discovery plus but after research found out my sky plus is an old system that doesnt have wifi. I know I can buy an adapter but with postage to ireland it looks quite expensive. Is there a way I can update the sky box I have or can I order a newer one from sky? I dont have a HD tv so have been told I cant get sky q
Locked
Re: update sky plus to wifi
Discovery+ streams via an app, not via Sky's On Demand services. Sky boxes can't host apps at all, regardless of whether they're wifi capable or not.
In short, Discovery+is only available on Sky Q boxes, I'm afraid.
This message was authored by: robjc
@kittykaycat
You won't be able to stream Discovery + on a Sky+HD box with built in WiFi or by adding a WiFi adapter to your box.
Sky+HD does not support Apps only SkyQ.
Supported devices are:
iPhone / iPad / AppleTV4
iPhone 5 running iOS 11 or later
iPad2 running iOS 11 or later
tvOS running tvOS 10 or later
Android and Android TV
Android phones and tablets running 7.0 (Nougat) and later
Smart TV and Connected Devices
Samsung TV running Tizen 2.4 (2016) or later
Android TV running Android 7 or later
Fire TV devices running OS 5 or later
Chromecast
You can enable Chromecast from our iOS and Android apps.
Minimum requirement is Chromecast Generation 2.
PC/Mac Recommended browsers
Windows < 10
  •    Chrome 51+
  •    Firefox 41+
Windows 10
  •    Edge 16+
  •    Chrome 51+
  •    Firefox 41+
MacOS > 10.10
  •    Chrome 51+
  •    Firefox 41+
  •    Safari 11+ (live simulcast streams cannot be viewed via Safari)
Linux > 4.4
  •    Chrome 51+
  •    Firefox 41+
Devices such as a Firestick or Chromecast etc. will connect to your TV via an HDMI input, if you don't own an HD TV then you're out of luck.
Regards
Locked
