6
This discussion topic is read only This discussion topic has been answered Discussion topic: sky q box not connecting to network
This message was authored by: kjg50
sky q box not connecting to network.  have folllowed  advise on these discussion pages  .still no good. having great difficulty contacting sky to see if i can book an engineer.
This message was authored by: Quoman7 Answer
Re: sky q box not connecting to network
@kjg50  Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot the main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, then do the same with the Mini box?
Locked
Hi @kjg50 Which SKYQ box are you referring to? The main box or aMini box?
Avatar for kjg50
sky q box is main box    sky mini box is mini  box
@kjg50 Still unclear, is your Main SKYQ box not connecting to your broadband, or  do you have a SKYQ Mini box that is not connecting to your SKYQ main box?
Avatar for kjg50
sky q not connecting to internet. (no network connection)other devices connecting ok. sky mini box not connecting to sky box (no satellite signal).tried various things on forum and YOU TUBE nothing worked.
new to this forum will take some getting used to.
Avatar for kjg50
quoman 7    thank you for  your advice.was just about to do it when my grand daughter arrived.showed her your message   she did it for me  now working ok.
thanks again
Locked
