This discussion topic is read only Discussion topic: puc switching on
This message was authored by: roeboy
puc switching on
Can anybody recommend the best settings or combination of key presses to ensure these bloody pucs don't require a reboot every morning. I've tuirned off Overnight Power Saving and switched on Network standby mode but it still seems to on the roll off a dice whether the things will come on or not.
Sky Glass 55" (on ethernet) & four pucs
BT FTP (150Mbs), BT Smart Hub 2
Locked
Re: puc switching on
@roeboy  In Settings Menu try these settings:
Startup and standby
Network standby mode - On
Overnight Power saving - off
Sleep timer - Off
@roeboy my settings are slightly different from @GD1's but work pretty reliably:
Network Standby Mode - Off
Over night power saving - Off
Sleep timer - Off
Bear in mind that the Pucks take several seconds to wake up after yiu press the Power button. If you're impatient and press it again, you'll confuse it.
Avatar for roeboy
Level 3 icon
I've got these settings or similar but it doesn't appear to work.
For example this morning I had to reboot the puc in the top bedroom got the thing on after doing that, switched it off then came back ten minutes later and when I pressed on again nuffink happened went downstairs and waited still nuffink. Then I pressed home and then I pressed on and the thing switched off and then came back to life again.
Sadly though the playlist has now disapeared so will have to reboot again
Locked
