This discussion topic is read only Discussion topic: hazy picture
This message was authored by: mike358
hazy picture
My screen went black few a fe seconds and then picture returned with this foggy haze. Can't seem to get back to the normal clear pic. Haven't found anything online that refers to the same issue. Any ideas? Have attached a picD2347205-84C3-4826-96AC-EB27D985B7DA.jpeg
Locked
Re: hazy picture
@mike358  Try a reboot of your box to rule that out, power down for 30 seconds then power back on and see if it's made any difference.  If not then it is likely the TV at fault, if you have any other devices to check the picture on that would help diagnose if it's the tv at fault.
Locked
