Discussion topic: catch up
Message posted on 19 Aug 2021 02:56 PM
catch up
I have just upgraded to skyQ from sky+ but now they want me to pay for catch up which was free with sky+
why? doesn't seem much of an upgrade
Message posted on 19 Aug 2021 02:58 PM - last edited: 19 Aug 2021 02:59 PM
Re: catch up
@les7264green Sky signature comes with Boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
There is also a known problem with new customers and those changing their account where there is a problem with downloading catchup etc. It seems you may need to call Sky and they should send a refresh signal to your viewing card which should sort the problem out
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 19 Aug 2021 02:59 PM
Re: catch up
@les7264green assuming you have bought the Signature package catch up is free BUT only in SD quality not HD unless you are paying extra for the HD pack and it is dead easy to pick the wrong file to download.
Message posted on 19 Aug 2021 03:19 PM
Re: catch up
thankyou,seems to work, grateful for your help
