Discussion topic: Viewer card no longer active
Message posted on 06 Aug 2021 08:20 PM
I recently signed up to Sky (July 2021) and only got my wifi today installed. I have a Sky Q box which tells me 'your viewer card is no longer active' so I have very limited access to channels.
I have tried resetting the box but there are no setting options when I press the home button.
I have turned it off and on, taken out the card and cleaned it but to no avail.
What can I do to fix this?
Message posted on 06 Aug 2021 08:23 PM
Re: Viewer card no longer active
Hi @NPMcK
Try a Reset Settings in the hidden menu.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
Failing this it Looks like you need to contact Sky so that they can re-activate your card.
Message posted on 06 Aug 2021 08:30 PM
Thanks for the help but no luck. Same message appearing. Unfortunately Sky uncontactable by phone and the promised SMS not appearing.
Message posted on 06 Aug 2021 08:35 PM
@NPMcK Sky are contactable by phone, you need to remain on the line past the automated message, when asked why your calling just say technical. Lines are quieter after 9pm or 7am.
Message posted on 06 Aug 2021 08:37 PM - last edited: 06 Aug 2021 08:38 PM
Hi @NPMcK
Selecting Need more help
at the bottom of the following link will lead to a phone contact number.
Just ignore all messages and wait for an agent
Message posted on 06 Aug 2021 08:51 PM
Not with Sky Ireland - the automated message is on a loop asking me to select an option for SMS, which I select. I then don't receive an SMS and they kindly hang up on me. N
Message posted on 06 Aug 2021 09:03 PM
Thanks - got an automated message that their tech Dept is closed so will have to wait till the morning.
I appreciate your help. N
