This discussion topic is read only Discussion topic: Using volume buttons stops blu ray playing
This message was authored by: tj68
This is how i have set it up pink hdmi out soundbox to tv, hdmi in from soundbox to blu ray player. Hdmi from sky q to tv. Turn soundbox to optical , have optical cable from tv to soundbox but when i change volume with either skyq box remote or soundbox remote it stops blu ray player and stops movie and opens blu ray tray arghhh. Help pls
Locked
Avatar for tj68
Level 4 icon
Re: Using volume buttons stops blu ray playing
I changed way it set up and it still dont work and opens blu ray tray when changing volume. Set up is blu ray hdmi to tv, soundbox to q and q to tv and optical soundbox to tv and other soundbox hdmi to tv.i give up
This message was authored by: mike+simmonds
Hi @tj68
I would completely change your cabling.
An HDMI cable  out of your Sky Q box and in to the Soundbox (the black IN port in the middle)
Then another HDMI cable out of the Soundbox and in to your TV
Then an HDMI cable from your Bluray in to your TV
Then an optical cable from your TV to your Soundbox
Whwn watching your bluray - choose optical on the Soundbox menu and choose the appropriate HDMI port on your TV remote
As for your volume control stopping your Bluray.  That is odd
When setting up your Sky Q remote - try not pairing it to your TV, just to the Soundbox
Or even - don't pair your Sky Q remote with any other device
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Avatar for tj68
Level 4 icon
Remote is already paired so cant unpair it and set up is as you say now the volume is fine in optical its just i cant adjust volume or the blu ray tray opens, i will just watch blu ray through tv speaker, not ideal but sick of fiddling with it now. Thanks for the reply
Hi @tj68
To unpair your Sky Q remote - just press and hold 7 and 9  together for a few seconds until the little red light flashes
edited - sorry - mistyped
Sky Q 2TB main box
LG CX6LA from 2020
Hi @tj68
I realised I mistyped the "remote reset" numbers earlier.
If you want it -
Sky Q 2TB main box
LG CX6LA from 2020
Avatar for tj68
Level 4 icon
Will try that tomorrow thank you
Locked
