This discussion topic is read only Discussion topic: Thumbnail images not showing for Apps
This message was authored by: rmp1974
Over the last few weeks we have had no thumbnail images for the Apps and sometimes for other items on Sky Q. Any ideas what the issue is and how to fix it please?
already turn it off and on and  Refreshed Apps.
Locked
Re: Thumbnail images not showing for Apps
Hi @rmp1974
Try a Reset Settings in the hidden menu.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair
Avatar for rmp1974
Just tried it an still nothing, if anything there appear to be more missing.
Hi @rmp1974
Try first rebooting your Broadband router (disconnect power lead for 30 secs and then reconnect).
When this is completely back up and fully running reboot the Main Q box again.
Avatar for rmp1974
Tried and still nothing (albeit one or two TV program images are back)
This message was authored by: RoPatel
I have got the same issue and it's started happening since few weeks only. Any help would be appreciated.
This message was authored by: Spiderpurple
I've tried everything to get them back then I did this and they all came back. If you have the sky buddy app look on devices and turn everything that's sky related in  restrictions to none. Don't know if it was coincidence but they all came back after doing this
I switched my Broadband to Virgin Media fibre and it all works fine now, It was certainly to do with broadband speed.
Avatar for rmp1974
Sky must have fixed something over the weekend as all the now appear for me
This message was authored by: Chrisred21
Do you have sky broadband buddy?
I had the same problem on a number of apps.
I put my sky q box into a category in settings that has no age restrictions. Looks like the parental control is stopping the thumbnails being viewed as they are not sky controlled.
Locked
