Discussion topic: The Tv doesn’t work
This message was authored by aditza This message was authored by: aditza
The Tv doesn’t work
Shows me on a screen there is no signal
Locked
Re: The Tv doesn’t work
@aditza  If it say no signal it's your TV and you need to select the correct input using your tV's remoate.
Hi @aditza
Make sure that your TV is set to the HDMI input that Q is connected to.
Then with the Q box on with green led press
Home 1 0 8 0 Home
on the remote control
aditza
Thank you for your guidance,I will let you know soon as I ll set up
aditza
Still doesn't work ,I have followed up your guidance but still nothing
Assume you have tried a Q box reboot @aditza
Locked
