Discussion topic: Temporary removal of Sky Q Dish?
This message was authored by Kurgan19 This message was authored by: Kurgan19
Hi Folks.
I am getting the wall that my Sky Q dish is mounted on Re Harled.
Can I just unplug the dish, remove dish and bracket carefully then remount after the work is done?
Will it need re aligned and set up again?
Will I need to contact SKY for this or find a local engineer for this?
What sort of costs should I expect?
Thanks for any help.
Locked
Re: Temporary removal of Sky Q Dish?
@Kurgan19 wrote:
Hi Folks.
You could remve it yourself, however if it's knocked out of alignment then you'd need to get someone to realign the dish.
Best option is to use a local installer.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Locked
