The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
20 May 2022 10:34 PM
Technical fault is appearing all the time on recordings and I'm not able to rewind. I've tried turning the box off at the mains but it makes no difference.
20 May 2022 10:44 PM
Hi @Oxford2022
Try a Reset Settings in the hidden menu.
