2
This discussion topic is read only This discussion topic has been answered Discussion topic: Speed still halved after landline fix
This message was authored by: Mainsworth92
Hey all, thanks for reading.
Had a landline fault fixed today at the exchange as our speeds had suffered a drop and reliability. Connection stable now but the speeds remain halved even though my app now says speed should be full.
Downstream also saying 55mb but in actuality when testing only receiving 22ish mb.
Any ideas or does it just take a bit of time following a fix?
Connection is wired ethernet. I also don't expect to hit max speeds I know there's a drop off but my app says issue resolved yet speeds are still inline from when the fault started.
Many thanks!
Re: Speed still halved after landline fix
@Mainsworth92 try rebooting the hub by disconnecting the power for a few minutes to force an IP address change to see if that clears the issue.
Locked
Avatar for Mainsworth92
Lovely stuff more or less there now. Thanks!
Locked
