Discussion topic: Sound issue on firestick
Message posted on 21 Jan 2022 06:53 AM
I have installed a firestick but when I use it I have sound still playing from the sky station I was previously watching as well as sound from the program I am watching. I have turned the soundbox off with no change.
Message posted on 21 Jan 2022 09:57 AM
For some reason, the Soundbox was designed not to have the ARC feature, which severely hampers the usability.
Pete.
Message posted on 21 Jan 2022 09:23 AM
Re: Sound issue on firestick
If the input button on the Soundbox is set to "HDMI", you'll get sound from only the Sky box.
To get sound from other sources, using the "Optical" input would work better (assuming you have an optical cable and have it connected to your TV).
You'll also need to set the sound output on your TV to "Optical" if you're only using the soundbox as your speaker.
Pete.
Message posted on 21 Jan 2022 09:45 AM
Hi @eimear1
Yes as @PeteRG41 says - optical from your TV to the Soundbox is definitely the connection you need.
Then turn your Sky box off with the remote
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Pete.
Message posted on 21 Jan 2022 02:59 PM
Many thanks for your comments, I have the optical cable now fitted and obviously now turned sky off and have sound from tv for the firestick.
