The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
28 Nov 2021 03:01 PM
Our router is kicking out 300+mbps, but in every other room it is <10 mbps. We have two boosters, a sky Q and 2 miniboxes, but one mini box is virtually unusable because of slow speeds it keeps dropping the connection. I have copied the data below - can anyone advise how to sort this out?
29 Nov 2021 03:02 PM
Posted by a Superuser, not a Sky employee. Find out moreTo be fair to Sky their kit is providing coverage for you its just at a low speed which unfortuantely is the nature of mesh networks. Your solution would likely to back the boosters up with an ethernet backhaul. This would stop them relying on WiFi to provide the mesh.
28 Nov 2021 03:05 PM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 52076328 90072048 0 0 0 169:16:17 LAN Up 4952834 0 0 0 0 169:17:53 WLAN (2.4 GHz) Up 22018133 8063751 0 1 0 169:16:20 WLAN (5 GHz) Up 217527465 89351051 0 2 2 169:16:19
28 Nov 2021 03:09 PM
300Mbps seems quite slow for a 500Mbps connection
Is this all wifi or ethernet,?
Can you test the speed using gigabit ethernet cables on fast.com?
28 Nov 2021 03:44 PM
Test came up 296mbps. But another Ethernet connector to one of the boosters came up 5mbps
28 Nov 2021 03:47 PM
"Test came up 296mbps"
On ethernet thats crazy low
Still waiting for whatever image you posted to be moderated
28 Nov 2021 03:49 PM
You're not using powerline adapters or any device as a wifi to ethernet bridge?
28 Nov 2021 04:33 PM
Only in one room - that currently reads only 5mbps.
28 Nov 2021 04:34 PM
Sorry not a powerline, it is a Sky installed booster,
28 Nov 2021 04:35 PM
The image was the data that I copy and pasted
29 Nov 2021 02:16 PM
Posted by a Superuser, not a Sky employee. Find out moreTo me it sounds like too many mesh hops. You have 2 x Boosters 2 x mini boxes and 1 x Q main. Thats 5 mesh nodes + the router makes 6. Often having more boosters can reduce speed in favour of signal strength.
29 Nov 2021 02:55 PM
@jamesn123 so is there a solution? if we reduce the number of boosters, then we won't get any signal in certain parts of the house, which is not an outcome that will work. When we recently switched from Virgin because we were having the same issues, albeit a bit worse as the Virgin signal constantly dropped out, Sky basically promised us that their router/boosters were so powerful they would give us amazing coverage throughout the house. It's becoming apparent that it was just sales talk and the situation is really no better. Is it too much to ask of a company to provide reliable broadband coverage for a whole house and not just the room the router is in?! Hopefully a sky employee will pick this up and answer!
29 Nov 2021 03:54 PM - last edited: 29 Nov 2021 03:55 PM
Yes: frankly that's too much to ask of an ISP. A specialist wireless contractor might be prepared to take on such a task, but you'd be paying commercial consultancy and hardware installation rates.
29 Nov 2021 05:45 PM
@jamesn123 Thanks. Sounds like I will need to get an external provider in to do this. Appreciate your help
29 Nov 2021 05:54 PM
@TimmyBGood ok, accepted - appreciate your clarity. Frankly, I don't care about the cost, I just want to have fast, reliable broadband throughout the house. Would be helpful if Sky were honest about this in the installation process. I was quite clear about the size of the house and our requirements and every answer was "yes, it'll be great" all the way up to the point just after installation when it appears that the answer should have been "no, you'll need to rewire your house to do that"! Not being particularly gifted in the art of tech, I took them at face value. Still, you live and learn...
