The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
21 Feb 2022 12:43 PM - last edited: 21 Feb 2022 12:45 PM
Hey everyone,
Quick question, for some reason when i use sky.com/tv-guide and the Sky Go app, the channel order is set to SD by default (even when I pick my correct region/HD on the web), meaning if I setup a remote record on channel 401, it will actually set the recording on the SD version of the channel.
I'm pretty sure this wasn't the case when I was a Q customer back at launch in 2017.
Everything is right on the box, but it's just annoying to have to find the "wrong" channel numbers for remote record.
21 Feb 2022 12:51 PM
I've raised this with Sky Go a number of times and they have been hopeless.
It's actually easier to use the Sky+ app to set remote recordings - it has the correct channel numberings (102 = BBC2 HD, 103 = ITV HD, etc) and works fine with Sky Q.
21 Feb 2022 12:54 PM
@fizzdisco One thing I thought of, do you have Multiscreen? I don't anymore, but did first time around - wondering if it works correctly if it loads the EPG/channel list from the box instead of the cloud whereas there is no box communication unless you've got multiscreen.
I wish there was a multiscreen product to let you stream from your box to the Go app without all the overhead of mini boxes etc. Not worth paying £15 just for Sky Go access to recordings and box streaming.
21 Feb 2022 12:57 PM
@lgladdy wrote:@fizzdisco One thing I thought of, do you have Multiscreen? I don't anymore, but did first time around - wondering if it works correctly if it loads the EPG/channel list from the box instead of the cloud whereas there is no box communication unless you've got multiscreen.
No, I don't have multi-screen & never have done. I have Sky Go Extra which allows streaming of most Sky content directly to my mobile devices without paying any extra. I think it was a freebie with Sky VIP and removes the need for any kind of multi-screen subscription.
