The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
17 Feb 2022 07:54 AM
Having to reset my box every morning anyone have an idea why
17 Feb 2022 07:59 AM
Posted by a Superuser, not a Sky employee. Find out moreYou mean you have to restart it,by switching off at the plug? What's the box doing or not doing that means you need to restart it,
17 Feb 2022 08:22 AM
Hiya
Switch TV on and there's no sky q whatsoever just a black screen
I wait a couple of min and nothing happens so I end up doing a rest to get sk q back
17 Feb 2022 08:49 AM - last edited: 17 Feb 2022 08:53 AM
@Colin260260 wrote:
Hiya
Hi @Colin260260 When your TV and SKYQ box are on standby, turn the SKYQ box on first, this should then turn on the TV.
If not check that HDMI control is turned on in settings on the SKYQ box and also on your TV?
17 Feb 2022 08:51 AM
I'll try that and see
17 Feb 2022 09:30 AM
Posted by a Superuser, not a Sky employee. Find out more@Colin260260what time in the morning is this happening
17 Feb 2022 09:32 AM
I turn it on at six in morning
17 Feb 2022 09:39 AM
Posted by a Superuser, not a Sky employee. Find out more@Colin260260If it is a bit earlier than 06:00 and your Q box is in eco mode have a look at this link, all boxes should be set to the same standby mode.
https://www.sky.com/help/articles/using-the-standby-settings
17 Feb 2022 09:40 AM
@Colin260260 it could be you box is set to eco mode as that is right in the time thatveco mode ends have a look at the link below and it shows you how to check what the setting is and how to change it
