Discussion topic: Sky q mini box wont come on
This message was authored by mutley72 This message was authored by: mutley72
My sky q mini box won't switch on. Red light comes on then goes. Ive reset for 5-7 seconds as per previous posts.  Red light then comes on , I've left it for several minutes as per instructions and pressed the home button on the remote but nothing happens, mo green light,  just stays red. I've checked my main q box and all modes are correct. Do i need a new mini box, had it less than  a week !
Locked
Re: Sky q mini box wont come on
@mutley72
First thing to try is always to fully reboot the main Q box (remove and replace power) and only then do the same with the Mini box.
Locked
