This discussion topic is read only Discussion topic: Sky q box won’t accept WiFi password
This message was authored by: Cookie454
my sky q box won't accept my now tv WiFi password when everything else in my house has connected with the same password, I've even tried to disconnect stuff and reconnected to check password all ok
Locked
Re: Sky q box won’t accept WiFi password
Hi @Cookie454
Are you trying to connect by a Network reset in the main Q box ?
Avatar for Cookie454
Hi I'm not sure i did have to reset the network as I was having problem but I've gone through everything in the setting and nothing working It won't accept the password no Matter what I do
This message was authored by: pjhaahl
@Cookie454
Are you on Sky Broadband?
If not have you seperated out your routers 2.4G and 5G and given them unique SSIDs
are you definitely trying to connect to the 2.4G SSID
Hi yes I have separate my SSID and I'm trying to connect to my 2.4
@Cookie454
Can you connect it via ethernet. That would save you lots of headache
I'm afraid not my router and box too far apart unless I order a massive cable but that seems silly when my box was connected before
That may be the problem then.  It may be your Sky Q box isn't getting a strong enough signal for it to be able to connect properly.
You could try changing the 2.4G channel number on the router and see if that helps.
Hi I've try moving the router closer to the sky q box and I've tried changing the channel number still nothings working the only thing I haven't done is plugged it in with Ethernet cable as don't have one
Who is your Broadband supplier @Cookie454 ?
Now tv. I just can't understand why it won't accept the password when it work before
Hi @Cookie454
Yes you said that in an earlier post .   Just wanted to double check.
This message was authored by: ADBVEMB
Hi, I had the same issue.
My solution was to ask it to connect as a Sky Router and use the WPS button.
Do not use router from another provider if you have Now Broadband.
If you have sorted this yet, I hope this helps.
This message was authored by: TechmanagerMal
  • Look up Powerline Adapters - it's ethernet and mains wiring combination to carry the data.
Passing on the tips I have learned in over 25 years as a more than satisfied Sky customer.
This message was authored by: BelfastDes
Many thanks, solved it for me.
Locked
