This discussion topic is read only Discussion topic: Sky broadband booster Ethernet Splitter
This message was authored by: Bloomers123
Can I plug a splitter into my broadband booster to connect a laptop and VoIP phone?
Locked
Re: Sky broadband booster Ethernet Splitter
@Bloomers123
You could create a wireless to ethernet bridge directly connecting booster to laptop via ethernet. If you want to connect more than 2 devices an unmanaged switch may be possible. But if you are referring to sky voip internet calls the phone does need to be connected to the sky hub
@Bloomers123
As @cookiemonsteruk indicates, the appropriate hardware is an ethernet switch.  Ethernet 'splitters' do exist, but these are passive devices which do not switch data and so will not achieve what you wish.
@Bloomers123
Just trying to find out if the booster wifi-ethernet bridge via unmanaged switch is possible
@TimmyBGood
Otherwise a viable option booster box wifi ethernet bridge via unmanaged switch to multiple devices?
Personally I dislike bridging, have typically found it to be unreliable, and try to avoid it where possible.
Locked
