Discussion topic: Sky Signature
Message posted on 21 May 2021 08:08 PM
Sky Q installed yesterday. I have the Sky Signature package with HD. Trying to watch catch up and on demand and see the error message "to use this service you need to upgrade your subscription". I have even tried amending my preferences to SD instead of HD.
Any help or suggestions would be very welcome
Message posted on 22 May 2021 02:38 PM
Hi @nigea99 and @TechmanagerMal - quick call with Sky sorted the issue. It was technical. Thanks to you both for your help 👍🏻
Message posted on 21 May 2021 08:12 PM - last edited: 21 May 2021 08:12 PM
Re: Sky Signature
Hi @PATRICK250 unfortunately several new customers seem to be getting this.
I think you may need to call SKY to get them to do something (refresh your card or similar) to get you working
Hopefully you will be able to get through OK
Message posted on 21 May 2021 08:19 PM
Re: Sky Signature
Thanks so much for replying @nigea99. I'll give them a buzz and hopefully they can sort fox this
Message posted on 22 May 2021 12:54 AM
Re: Sky Signature
- Click on "Need more help" at the bottom of this page
https://www.sky.com/help/home - If you have Sky Talk or Sky Mobile dial 150 for a free call to Sky.
- When you call you will be asked if the call is to do with mobile say "No"
You will then be asked the nature of the call say " Technical "
You will then be asked for a mobile number, give the number but DO NOT hang up when it says to do so.
It will then ask "do you wish to hang up" say " No" you will then be put in the queue for an advisor. - I hope this helps.
Message posted on 22 May 2021 06:35 AM
Re: Sky Signature
Cheers @TechmanagerMal, will follow your advice 👍🏻
Message posted on 25 Jul 2021 12:11 AM
Re: Sky Signature
We have been offered the sky signature package and have had it recently installed. We are unable to download on demand and use catch up tv, as it comes up with the message about upgrading your subscription!?
Message posted on 25 Jul 2021 07:58 AM
Re: Sky Signature
Hi @Starbuck57
In my case I required Sky's assistance to resolve this issue. A quick call sorted it as they were able to diagnose and correct the issue pretty quickly. Would recommend calling them...good luck 👍🏻
Message posted on 25 Jul 2021 08:13 AM
Re: Sky Signature
As recommended, you'll need to call them. Provided you're not trying to download HD content without the HD pack?, it could be the issue that faces most new customers at the moment where they need a refresh signal sending to their card to allow them to download from Catch Up or On Demand. The customer services rep should have a note of this issue as it is widespread.
Message posted on 02 Oct 2021 11:56 AM
Re: Sky Signature
As you have Sky signature, do you get the Free HD channels anyway or do you need a seperate HD package? I found a list of channels on the Sky site and all the free HD channels were listed under Sky signature but the service line says you need a HD package as well? Seems odd.
Message posted on 02 Oct 2021 12:09 PM
Re: Sky Signature
@David+Wales you get the free to air HD channels ie bbc1 ,2 itv3 etc but to watch the non free to air HD channels ie Sky 1 HD Sky Atlantic HD and to watch catchup and boxsets from these channels you need the HD pack
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
