This discussion topic is read only Discussion topic: Sky Q box turns off for 5 seconds or 10 seconds then comes back on
This message was authored by: RRRobbo
Sky Q box turns off on its own maybe for 5 seconds or 10 seconds , then comes back on , on its own , but sometimes it doesn't come back on at all , you have to turn it on with the remote. It's done this for about a month now its not getting any better.
Locked
Re: Sky Q box turns off for 5 seconds or 10 seconds then comes back on
Hi @RRRobbo
Is your Q box well ventilated and not stacked with other devices?
Try a Reset Settings in the hidden menu.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
Avatar for RRRobbo
Thankyou for your advice , I haven't carried the reset yet as you described,  but I have done the other option that was given , I have pressed the home button then entered 1080 then pressed home button again . 24 hrs later and its not had a problem yet of switching on and off every few minutes , so fingers crossed its OK now, thanks all for the advice much appreciated..
Locked
