Discussion topic: Sky Q and Mini Box Issues
Message posted on 14 Sep 2021 09:36 PM
Recently we have started have issues with both the Sky Q and mini boxes, it seems to have started since the recent software update.
The Sky Q box is regularly freezing, stopping on recordings, not allowing fast forward of recorded programmes, sound cutting in and out and very slow changing of channels (as much as 3 minutes sometimes).
The mini boxes are also suffering with the same issues.
Generally this seems to be when the Sky Q box is being used at the same time as a mini box.
Reluctantly (lost all recorded shows/films) reset the hard drive with no success.
The boxes date back to spring 2016 when Sky Q was released, do I need a new main box?
Any help would be greatly received, as it is doing my head at the moment and I feel we are not getting value for money from our system due to not being able to use in multiple rooms.
Message posted on 15 Sep 2021 07:39 AM
Re: Sky Q and Mini Box Issues
@Iomseagull sounds like your main Q box is beginning to fail while not related to the new firmware boxes do tend to fail after an upgrade as there is some activity that can push them over the edge. Hard disc issues would give the symptoms you report.
I have escalated your post so. Sky should be in touch to invite you onto a chat session through the forum where a blue button will appear.
Message posted on 15 Sep 2021 12:28 PM
Thanks for your help.
I look forward to hearing from them soon
Message posted on 15 Sep 2021 02:40 PM
Thanks @Chrisee for escalating this. We have now sent an invite to chat 🙂
Lisa - Sky Tech Team Expert
Message posted on 05 Dec 2021 10:42 PM
Hi, I am having exactly the same problem with the skyq box and mini boxes. Can I arrange for a new box. Paying a lot of money for the service and virtually nothing is working properly. Connection lost on and off with mini boxes, changing channels takes far too long, recordings are failing, or saying software issues, sound disappears, fast forwarding stalls, deleting recordings problematic. Have done basic reset to no avail and software up to date.
