Discussion topic: Sky Q always out of sound sync
Message posted on 18 Apr 2021 01:13 PM
I have had sky Q for around 6 month .
I have issues with sound being out of sync on live and recorded TV.
I also have the issue of the occasional momentary picture freeze/fuzz or complete sound drop, this isn't always just occasionally and only momentary.
The sound sync being out is constant, I have tried all the delay settings but none of them fix it, I have also bought a new Hdmi cable, the only way the sound syncs is if I completely power off the box but it will eventually go back out of sync.
The sound sync on apps like Prime, Netflix and Disney + is fine it is only on live and recorded TV, Incidentally the sound sync on the multi-room mini box is fine also .
Any advice would be great .
Message posted on 18 Apr 2021 01:17 PM
Re: Sky Q always out of sound sync
Hi @69James
Try a Reset Settings in the hidden menu. Don't know if it will help
Press 1 & 3 together on the remote and follow onscreen instructions to re pair
Message posted on 18 Apr 2021 01:23 PM
Hi @69James on another discussion regarding sound being out of sync they found that having the TV set to some Gaming & other video processing settings affected this.
I don't remember the specifics but worth checking to see if you have any such settings on the mode and/or HDMI input being used for SKY in case these are part of the problem
Message posted on 18 Apr 2021 02:13 PM - last edited: 18 Apr 2021 02:14 PM
It's quite common to feel the need for negative numbers in the audio sync, to hold up the video.
I solved this audio delay issue but it was specifically via something I bought to allow me to use HDMI ARC on an Optical-only soundbar. What's your set up? How is your Q box connected? What TV is it? Any soundbar or AV equipment?
Message posted on 18 Apr 2021 05:18 PM
It's a LG webos TV, I don't use a sound bar and the connection between TV and Sky Q box is HDMI, the sound setting on TV is standard (user)
