3
Discussion topic: Sky Q Peacock channel only partially recording.
This message was authored by IainBro This message was authored by: IainBro
When I record some programmes from Peacock channel on Sky Q I get about 20 minutes of the actual programme and then it defaults to 30 minutes of a black screen despite the programme saying that the recording lasts for 60 minutes. I've tried deleting and re recording but it makes no difference.
This message was authored by caesarome This message was authored by: caesarome Answer
Re: Sky Q Peacock channel only partially recording.
Have you tried a reboot of your broadband router and if the same happens then do the same with your Sky Q box.
Locked
You are downloading via your internet connection any content from Peacock so it isn't being recorded. When you delete these failed downloads have you also deleted from the deleted section ?
IainBro
Yes ive deleted all failed, and watched, programmes from the deleted section.
Locked
