Discussion topic: Sky Q Mini Box Faults
Message posted on 12 May 2022 08:24 PM
Re: Sky Q Mini Box Faults
Need the whole story in one go @RiverbraidHarry
If you have a Sky Q booster between the main Q box and the mini then when you carry out a Network reset on the mini you need to press the WPS button on the booster
Network Reset found in Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect to Sky Q booster by WPS.
You will be asked to press the WPS button on your WiFi booster (not the mini)
Message posted on 12 May 2022 08:27 PM
Ok thanks for your help
