Discussion topic: Sky Q HDR
Message posted on 09 May 2022 02:02 PM
Sky Q HDR
Hi. When I am watching HDR programes on my Sky Q box after about half an hour the picture goes dark and if I check the picture settings on my TV its says UHD SDR. Its ok if I use the apps built into the TV or use a firestick.
Cliff
Message posted on 09 May 2022 02:20 PM
Re: Sky Q HDR
@hertsguy wrote:Hi. When I am watching HDR programes on my Sky Q box after about half an hour the picture goes dark and if I check the picture settings on my TV its says UHD SDR. Its ok if I use the apps built into the TV or use a firestick.
Cliff
Does this happen when you are watching live sport programmes with HDR or also on downloaded HDR content? What make/model of TV do you have?
Sky Q's HDR implementation has always been a bit flaky. Your TV and Firestick apps will always be more stable and better quality when it comes to UHD & HDR as they are optimised for streaming. Sky Q is a jack of all trades type box. Designed principally as a satellite receiver/recorder but with some streaming apps thrown in for convenience, not quality.
Message posted on 09 May 2022 02:24 PM - last edited: 09 May 2022 02:25 PM
Re: Sky Q HDR
@hertsguy, what's the make and model of your TV? HDR dropping back to SDR has been an ongoing intermittent problem for some of us. It appears to be caused by the Sky Q box failing/stopping to send the HDR infoframe.
Message posted on 09 May 2022 04:50 PM
Re: Sky Q HDR
I got this 5 times during the F1 yesterday
Message posted on 09 May 2022 05:22 PM
Re: Sky Q HDR
https://helpforum.sky.com/t5/Sky-Q/Fix-the-random-HDR-drop-outs-on-UHD/td-p/3576322/page/10
Message posted on 09 May 2022 05:25 PM
Re: Sky Q HDR
Its a Philips 58PUS7805 it happens when I watch netflix and prime apps also when watching programes on the UHD setting.I dont watch live sports.Is this something SKY can sort out.
Thanks for the reply
Message posted on 09 May 2022 05:29 PM
Re: Sky Q HDR
@TTforever which content the live race? I've watched a recording of the whole of the event from buildup to the end and it didn't dropout once..
Message posted on 09 May 2022 05:41 PM
Re: Sky Q HDR
Thanks for reply.
Looking at the link it seems a common problem. Shame because I had to pay £50 for later box and buy a new tv to get HDR so that was a waste of money.
Message posted on 09 May 2022 05:46 PM
Re: Sky Q HDR
@hertsguy wrote:Thanks for reply.
You should use the TV apps for Prime and Netflix. That way you'll get the best quality Dolby Vision HDR. Sky Q can't ouput Dolby Vision, so you're not making use of the full features of your TV.
Message posted on 11 May 2022 08:38 AM
Re: Sky Q HDR
Yeah watching live. Was recording so tried that afterwards and did the same, but at different times in the program
Message posted on 11 May 2022 03:05 PM
Re: Sky Q HDR
@tarbat wrote:@hertsguy, what's the make and model of your TV? HDR dropping back to SDR has been an ongoing intermittent problem for some of us. It appears to be caused by the Sky Q box failing/stopping to send the HDR infoframe.
Is this more of a V3 box issue because I've never had it happen on my V2 box.
Message posted on 11 May 2022 03:08 PM
Re: Sky Q HDR
Current working theory is that it only affects v3 TITAN boxes.
Message posted on 11 May 2022 03:14 PM
Re: Sky Q HDR
@tarbat wrote:...Current working theory is that it only affects v3 TITAN boxes.
Fingers firmly crossed, 😉 I have never had this happen to my v3 TITAN box.
Godfrey.
Message posted on 11 May 2022 03:19 PM
Re: Sky Q HDR
