This discussion topic is read only Discussion topic: Sky ID
This message was authored by: mrskitty
Sky ID
I am trying to set up a sky ID but when i enter my email address to do this, it takes me to the closed account for my old address. Any suggestions?
Locked
Re: Sky ID
@mrskitty  You either need to use a different email address, or if you want to use your current email address you will need to remve it from your closed account.
Re: Sky ID
If you want to use the same email address then you need to first remove it from the old account first as this will then free it up allowing it to be used when setting your new ID up. First try this link to do this:
https://www.sky.com/myaccount/my-details/sky-id/edit-unlink
If this link doesn't work for you then try it yourself by logging into the old account here:
Then delete the email address by providing another one and logout of this account, this will then free it up to use when setting up your new Sky ID:
https://www.sky.com/help/diagnostics/sky-id/sky-id
This message was authored by: Mrs+kitty
Re: Sky ID
Great thank you - all sorted now 👍
Locked
