Discussion topic: Sky HDR
Message posted on 27 May 2020 08:21 AM
Re: Sky HDR
@hudsonk do you 100% have a HLG compatible TV though. You may have hdr10 and even Dolby vision but not HLG
Message posted on 27 May 2020 08:22 AM
Re: Sky HDR
@jhoneyball what is your TV model it might not support HLG
Message posted on 27 May 2020 08:24 AM
Re: Sky HDR
Thanks I will wait
Its stupid there is no means to transfer recorded content from one box to another (still, as far as I know) so any changeover needs to be planned and handled for series links etc etc
Re: Sky HDR
@rscott people on here have said the v1 2tb box works does your TV support HLG. What's your TV model
Message posted on 27 May 2020 08:25 AM
Re: Sky HDR
@jhoneyball what is your TV model I can tell you in seconds if its your box or not!?!?
Message posted on 27 May 2020 08:26 AM
Re: Sky HDR
@jhoneyball TV model?
Message posted on 27 May 2020 08:27 AM
Re: Sky HDR
Samsung UE40MU6402
Message posted on 27 May 2020 08:28 AM
Re: Sky HDR
knowing my luck prob not, it's a samsung which is a few years old
Message posted on 27 May 2020 08:29 AM
Re: Sky HDR
@Tdazza there will only be one file which triggers HLG if the box and tv support it if not it plays in SDR which is why Sky are bothering with HLG rather than needing multiple files required if you use HDR10 or the other formats. Getting both HDR and SDR looking goid off a single source is not quite so simple as people believe.
Message posted on 27 May 2020 08:30 AM
Re: Sky HDR
@jhoneyball yours should display hlg
Message posted on 27 May 2020 08:31 AM
Re: Sky HDR
@hudsonk get me the model mate and I'll check any one who else wants me to check tag me in a post with your TV model and I'll check for you
Message posted on 27 May 2020 08:32 AM
Re: Sky HDR
I've checked my tv Samsung Q60r and this is the base line QLED and is HLG supported so time will tell, just waiting on the download to allow to view. But will be interested if it will work for me as I have a Philips Hue Sync Box pass through so will need to check that supports HLG
Message posted on 27 May 2020 08:33 AM
Re: Sky HDR
UE55MU7000TXXU @gems+151
Re: Sky HDR
I am firmly in the don't know camp. I watched Gang of Lemurs and it was impressive picture quality however I have no idea if I am getting HDR I have a 2TB V2 box and a Sony TV that has an HLG option in the settings but there is no indication that am watching HDR.
It may just be a Good quality UHD picture.
Message posted on 27 May 2020 08:35 AM
Re: Sky HDR
Indeed -- it appears to do just fine on AppleTV 4K in HDR mode on BBC The Planets
