726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: Joshua+James01
No programmes
No programmes available, stuck on start screen
This message was authored by: TonyMay
Re: Sky glass menu not working
Mine came on on it owns still didn't work lol
This message was authored by: LadyCharlotte
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
@LChenery thank you, we've done that for now 💪🏻😊
This message was authored by: Nickd240
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Use voice control, resetting the router or disconnecting from the wall doesn't work
This message was authored by: ABB71
Sky Glass not working again
Sky Glass not working again!!!
Currently no programmes of this type available  :-(. ie all programmes
This message was authored by: Hully
Re: Sky Glass sorry but there are currently no programmes of this type available and no channels lis
I have this too on my Sky Stream, looks like it could be a network problem
Re: No programmes
@Joshua+James01 use voice search/control which is still working.
This message was authored by: robnnikki
Re: Not channels
Thank you so much
This message was authored by: Squidgytabboggan
Sorry, there are currently no programs of this type
Does anyone else have this message today. It's on the glass and pucks so assume it's a service problem however the service checker says everything is fine , and that's all the help you can get.
This message was authored by: sarahw123
Same issue here. Message saying sorry currently no programs available. Have rebooted several time.  I can use microphone on remote thanks to reading some comments. Come on sky sort it out. Can't even get through to them as they are shut till 8am
This message was authored by: Frenchie15
Re: My sky glass says, sorry, there are currently no programmes of this type available.
I have the same error this morning, I have switched my tv off, reset the router, switched the tv back on, went to a wired connection and the problem still persists. I wish that I had never purchased the Sky Glass TV.
This message was authored by: BenRtt
I did a full recovery, turning off at wall and holding standby button in whilst powering on, it runs software update and resets the TV as per Sky help but whatever has happened has bricked my remote so I still can't do anything.
This message was authored by: Amygawler
Same here mines been like this since 6ish I've also tried to update the apps ect and still no luck but I did read yesterday all sky glass customers are meant to have the new update by tomorrow (4th February) so it's probably got something to do with that?
55" glass in black plus 1 Puck
This message was authored by: shandy1969
I have a message on my sky glass saying currently no programmes of this type are available upstairs
I have a message on my sky glass tv saying no programmes of this type available I have done everything to resolve this
This message was authored by: Mossbird29
Just to say I'm in the same boat. Really annoying - I am assuming that there are many people running around Sky HO trying to rollback the update (or trying to patch it which is an even bigger nightmare). If they've not fixed or communicated by 9am then it's a poor show.
Locked
Answered - Go to Answer
