This discussion topic is read only Discussion topic: Skua mini connects to main box, all channel technical fault
This message was authored by: JonnypX6
I have moved a skywalk mini to an out house and connected via a cat6 cable to the router in the house and a router in the out building.
the mini box connects to the main SkyQ box but all channels have technical fault and recordings won't play either. Please help!
Locked
Re: Skua mini connects to main box, all channel technical fault
Hi @JonnypX6
Connecting to a Q router on Sky Broadband is fine but if you are on 3rd Party broadband you need to connect by Ethernet to your main Q box.
Avatar for JonnypX6
Thanks, in that case can I put a switch in at the house end to split the cable coming from the out house, one to the router and one to the skyq box?
Hi @JonnypX6
Connecting all Q boxes to a 3rd party router is fine.  This connection can be directly or through simple unmanaged Ethernet switches
Avatar for JonnypX6
So just so I am crystal clear!
back of main sky q box to Ethernet switch.
from Ethernet switch down to out building, into another Ethernet switch
from that Ethernet switch to back of sky q mini box.
Hi @JonnypX6
Nowhere  in your post do you mention Ethernet to Router!
Avatar for JonnypX6
Ok my mistake, however will the above work?
It should if there is also an Ethernet from one of the switches to the Router @JonnypX6
Avatar for JonnypX6
Does that router need to be the same one I have the main skyq box plugged into? As I have several routers off the main BT router.
Hi @JonnypX6
Yes,   all the Q boxes need to be connected to the same router.
Best to carry out a Network reset on all Boxes starting with the main Q box and do not do any WPS just wait until the boxes connect.
After they have connected go into the hidden menu and turn off all Q box WiFi.
Locked
