Discussion topic: Sim delivered before iphone 13 pro max
This message was authored by Harrison1315 This message was authored by: Harrison1315
Hi all.
I'm making the switch to sky mobile as I'm currently currently o2 and sky seem to offer a better deal on the iPhone 13 Pro max.
My question us if I place an order for the pro max and new plan, will my sim be delivered before the phone as there is a 6-8 week wait for the pro max but ideally once I've left o2 want to start using my sky mobile sim as soon as.
Thanks in advance.
Harrison
Locked
Re: Sim delivered before iphone 13 pro max
@Harrison1315  Yes the sim is usually sent via Royal Mail, however you have 30 days to activate the sim.
Harrison1315
Perfect. Thank you! So I should be good to place the order and the sim be sent out next week sometime so I can use it in my current device until they send out the new device once they have stock?
@Harrison1315  As long as you current device isn't locked to O2, then yes feel free to start to use it.  Are you also intending on transferring your number?  https://www.sky.com/help/diagnostics/sky-mobile-keep-your-number/do-you-have-a-pac
Harrison1315
I will be keeping my number, yes.
Plan to get thr PAC code once I recover the sky sim and then transfer it then, would you say that's the best way to do it?
Also thank you for your help and replies. This is my first time using a Community forum and you've been really helpful
Harrison1315
Sorry about the spelling mistakes. Should probably proof read before Pressing reply. 🤦🏻‍♂️
The PAC is valid for 30 days also I believe, but you would need to order then activate your Sky sim before you can transfer your number in.
Harrison1315
Thank you! I'll place the order now then
Hopefully it's all worth it! Especially the 6-8 week wait lol
This message was authored by advent99 This message was authored by: advent99
Hi 👋
I ordered the Iphone 13 Pro max also on a new contract on 7th October, however 3 weeks have passed & the sim has not been sent out & says will be sent soon, so I'm under the impression it will arrive along with the phone.
Did yours arrive as advised?
If ordering a phone then the sim does usually come with it, keeping an eye on your order tracker is all you can do as it will update when it is dispatched.
Thanks caesarome 👍
Locked
