Discussion topic: Samsung Frame 2021 TV & Sky Q
Message posted on 22 Apr 2022 05:57 PM
Hi - I am going to purchase a 2021 Samsung Frame TV and wonder if it can remotely pick up my Sky Q or does it need to be hard wired to the Frame Box? Thanks
Message posted on 22 Apr 2022 06:03 PM
Re: Samsung Frame 2021 TV & Sky Q
@ramjam82 you still need a HDMI cable between the Q main box and the TV
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Apr 2022 06:53 PM
Thanks Could I run a splitter from the main SkyQ box to the new TV?
Message posted on 22 Apr 2022 06:56 PM
@ramjam82 you can do but the best way if you want to run 2 TV's on Sky Q is to take out a multiscreen subscription and use a Sky mini box only downside is this does cost more and mini boxes cannot show UHD
Message posted on 24 Apr 2022 10:53 AM
I do have x2 Mini Boxes already and don't want to spend on a third, so thought that I could run a splitter from the living room to the new TV
Message posted on 24 Apr 2022 11:26 AM
@ramjam82 as I said you can use a splitter but dependant on how long the hdmi cable will be would depend on the resolution you get on the new TV as the longer the cable the more signal degradation you get so if you are wanting UHD on the new TV then it may not be possible although with a mini on it you wouldn't get UHD either.
