Discussion topic: SKY Q and Mini box do not work at the same time
Message posted on 10 Jun 2021 05:33 PM
Each box works fine when it is on and the other is on standby. When both boxes are on at the same time a network connectivty issue/no internet error occurs. The mini box then goes to a blue screen error whilst the main box has no internet connection.
Message posted on 10 Jun 2021 05:35 PM
Re: SKY Q and Mini box do not work at the same time
Phone sky and they send you a text then cut you off. Unacceptable for £100+ per month.
Message posted on 10 Jun 2021 06:06 PM
Try a Reset Settings in the hidden menu on the main Q box
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
Message posted on 10 Jun 2021 06:42 PM
Thanks tried that. No change. Only one or the other will work.
Message posted on 10 Jun 2021 06:45 PM
@frank+ricard Have they always been like this or is this a recent thing?
@frank+ricardHow are your boxes connected and do you have a mesh.
Message posted on 10 Jun 2021 07:56 PM
Nothing has changed although the internet has been up and down recently. I carried out the reset, turned everything off and on, changed the wifi channels, changed the Wifi password and then repaired the mini box from the main sky q box. Working again (not sure what sorted it!)
Thanks everyone.
