Discussion topic: SD Card
Message posted on 05 May 2021 07:27 PM
SD Card
I have a Panasonic Viera TX-32LZD85 with the facility to play an SD card. How can I access this facility from my Sky remote control. The panasonic remote will not acces it.
Message posted on 05 May 2021 08:03 PM
Re: SD Card
If your TV remote won't access this TV function, then there's no way your Sky remote will.
I'd check your TV's instructions as that's the only way you'll get to watch content from an SD card. I presume you've put the SD card in? It should just be a matter of changing the input on the TV remote, surely?
Message posted on 05 May 2021 08:06 PM
Re: SD Card
Just about to post the same - an SD Card is an input source, just the same as a DVD player for example. On a Sky+ box press TV, then Play to change input source (but your Panasonic remote should do the same thing).
Message posted on 05 May 2021 08:12 PM
Re: SD Card
The TV is configured to be controlled by the Sky remote, that is why it doesn't respond to the original remote .
Message posted on 05 May 2021 08:16 PM - last edited: 05 May 2021 08:18 PM
Re: SD Card
A sky remote never replaces the original TV remote it will work side-by-side, you program the Sky remote to work with th TV and NOT configure the TV to work with the Sky remote
