Discussion topic: Recordings stop before end saying power failure
Message posted on 04 Feb 2021 08:12 PM
Over the past few weeks recordings have cut off before the end saying power failure.
This has happened on all different channels.
Anybody else had this and if so have they found out what the problem is?
Message posted on 04 Feb 2021 08:14 PM
Re: Recordings stop before end saying power failure
You could try a planner rebuild:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something.
