Discussion topic: Q mini connection
Message posted on 11 May 2022 07:18 PM
Q mini connection
My Sky Q mini box showed a connection fault, I've cleared that and the source/HDMI1 is now showing connected to Sky but my remote won't turn the box on, if I turn the box on with the box standby button, the light turns green but it still won't connect
Message posted on 11 May 2022 07:39 PM
Re: Q mini connection
First Try completly resetting your Bluetooth remote to get that working
Press 7 & 9 together on the remote until it’s led flashes four times.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes twice and follow onscreen instructions to re- pair.
Then try first rebooting your main Q box and then when this is completely back up and running reboot the mini.
