Discussion topic: Q mini box issue with starting from standby
Message posted on 14 May 2021 07:38 AM
From start up mini box constantly in effect acts like it's just been installed. All this since TV has been replaced.
Message posted on 18 May 2021 08:29 AM
@RJW68 wrote:
Did what was suggested. Procedure failed. Mini box still acts like it's been switched off not connected to main box. Again this is only since TV was replaced.
Hi @RJW68
Try a Reset Settings in the mini box hidden menu.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
Message posted on 14 May 2021 08:19 AM
Re: Q mini box issue with starting from standby
Hi @RJW68
Are all your boxes in the same standby mode and are you using your Q box in the early hours?
https://www.sky.com/help/articles/using-the-standby-settings
Also check they are both on the latest Software version.
Message posted on 14 May 2021 10:16 PM
Haven't check software assuming that updates are automatically done. Main q box is on standby when the issues occurs as my partner is the one that likes TV in the morningfro her room where the mini box is.
Message posted on 17 May 2021 05:19 PM
Hi issue occurred on return from short break when mini box was turned on in afternoon. Main box was off so must dispell 5.45 am myth. However, software was out of date and I changed both boxes standby to none. Let's see what happens.
Message posted on 18 May 2021 07:20 AM
Hi @RJW68
Message posted on 18 May 2021 08:38 AM
Hi @RJW68 Try resetting the Mini box:-
Switch the Sky Q Mini box off at the mains. Hold down the Reset button on the back of the Sky Q Mini box and switch it back on at the mains. Keep holding it until the light on the front flashes red and green. This will take about 30 seconds.
Message posted on 20 May 2021 06:44 AM
Unit went through the motions of a software update but it's stayed at same version.
Message posted on 20 May 2021 06:46 AM
Tried both methods if reset, NADA, nothing. It still does the same thing each time no matter what time if day unit us switched on.
Message posted on 20 May 2021 07:17 AM
The software update will go through the motions even if you're on the latest version. It's crazy - every other device in the world will tell you if you're on the latest and won't waste your time!
Is this issue every single time you switch the mini on from standby, and not from the mains?
Message posted on 20 May 2021 08:09 AM
Yes no matter what time of day. Ever since TV was changed.
Message posted on 20 May 2021 08:39 AM
Yes, but my question was: are you turning on from standby or from the mains?
Message posted on 20 May 2021 09:00 AM
With respect I wouldn't be posting as a problem if I was turning units off from the mains. Both boxes are left on standby.
