Discussion topic: Problem with viewing card
This message was authored by Matilda+2016 This message was authored by: Matilda+2016
Each day it's saying insert viewing card, card is already in.
Locked
This message was authored by Laing1 This message was authored by: Laing1
Re: Problem with viewing card
@Matilda+2016 you could try taking the card out completely giving it a wipe with a dry cloth then reinserting the card
To take the card out push the card in until it clicks and springs towards you to put the card in push it in until you hear it click
This message was authored by bob1234 This message was authored by: bob1234
@Matilda+2016Does it click into place when you push it in, quite hard, if it does then clean the contacts on the card with a dry cloth. I am not being rude but are you putting it the right way up how the card is labelled does not look right it goes contact side up.
Locked
