Discussion topic: Planner issues
This message was authored by LinziJ17 This message was authored by: LinziJ17
Planner issues
Hello I'm after some help. My SkyQ box planner is missing a lot from the TV guide. Main channel that is affected is STV. This is an ongoing issue resolved with reboot but only for around 48 hours and problem   persists. Any one have any idea how to fix this long term?
Locked
This message was authored by Doc5907 This message was authored by: Doc5907
Re: Planner issues
@LinziJ17
Try a Reset Settings in the hidden menu.
Sky Q 1TB UHD
LG TV
Sky Mobile
BT Broadband
Locked
