Discussion topic: Pink picture Sky Q
Message posted on 14 Feb 2021 10:39 AM
Pink picture Sky Q
My tv picture is tinged pink on my sky q mini box. We have changed hdmi cables, we have changed ports, we have rebooted. Everything else is fine (ie Netflix through the tv not through sky) so it must be the sky box. I can't speak to anyone at sky, the automated service just keeps asking me automated questions and then sending me text messages and hanging up. The advice is to post on here. This really is the worst customer service in the world.
Message posted on 14 Feb 2021 10:40 AM
Re: Pink picture Sky Q
Message posted on 14 Feb 2021 10:45 AM
Hi @k8ibelle
Try first rebooting your Main Q box and then when this is completely back up and running reboot the mini.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote.
Message posted on 14 Feb 2021 12:16 PM
Thanks for taking the time to reply - but unfortunately it didn't work
Message posted on 14 Feb 2021 12:22 PM
@k8ibelle i would change you HDMI cable.
Hi @k8ibelle
Although you say it cannot be the TV because Netflix is OK it still could be a problem with the TV HDMI inputs.
Try Changing the resolution of the min box to 1080i.
Home - Settings - Setup - Audio visual.
Change resolution to 1080i
Message posted on 14 Feb 2021 12:31 PM
I have changed the HDMI cable and also checked them on the DVD player so they both work fine there.
Message posted on 14 Feb 2021 12:33 PM
Thank you for your help! We have tried this too and it didn't work. My main problem at the moment is that I can't get hold of sky for them to help me. I either have an automated answer service that sends me texts with suggestions or am directed to sky community
Message posted on 14 Feb 2021 12:40 PM
One other thing you could try @k8ibelle
Try a Reset Settings in the main Q box hidden menu.
If this doesn't change it there is also a reset settings in the mini hidden menu.
Message posted on 31 Mar 2021 11:01 PM
I have the same issue, changed the Sky hdmi to a known good hdmi height speed 60Hz cable and it's still pink (has been fine for about 1 year now).
Tried rebooting, res adjustment, hdmi cable, different hdmi port on av receiver..no joy.
Assuming if I system reset, I will need to reprogram series links, favourites ...
Message posted on 31 Mar 2021 11:17 PM
The reset has killed the picture altogether. Box boots and you see the white sky flash screen but then all black. Audio working fine, so it's the video side of the box having issues.
phone call tomorrow I guess ...
Message posted on 01 Apr 2021 07:31 AM
Now it's become a black screen, have you tried pressing Home 1 0 8 0 Home to ensure the resolution of the picture is 1080i.
Failing that, no need for a call. Follow these steps. If it fails to help solve the issue, you can order a new box from the link:
https://www.sky.com/help/articles/sky-q-box-wont-turn-on?tag=makemoney0821-20
Message posted on 01 Apr 2021 08:26 AM
Thanks @Rhonny
I simply wasn't patient enough, just turned on this morning and all working(must have been doing it's update in the background last night), colour restored after rest and ap and running at 1080i. Changed to 2160 10bit and all good.
So there you have it, reset does the job.
Thanks everyone.
