The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
22 Apr 2021 01:56 PM
Recently, my Sky Go app will not connect to my Sky Q box. It always came up as Sky Q disconnected in a blue box. I tried to delete and re-install the App have signed in and selected Connect to Sky Q box, but I do not have the Recordings tab anymore. All other phones in my household with Sky Go on can connect no problem. Any tips?
23 Apr 2021 03:22 PM
Posted by a Sky employee23 Apr 2021 05:13 PM
Yes I have multi screen, all other devices are able to use Sky Go features. IOS14.4.2 and Skygo 21.3.1
06 May 2021 12:33 PM
Posted by a Sky employee2 - Ensure that you don't have a VPN in use on the device? If you do, please turn this off and check to see if Sky Go connects to the Sky Q box. VPN in use Y/N?
3 - Confirm you have Multiscreen subscription? Y/N
4 - Within the Sky Go app, check that you have "Connect to Sky Q box" setting set to "ON" Y/N?
14 Jul 2021 07:54 AM
I have the same problem with sky go app version 21:5:3, won't connect to sky Q box, but it used to. Have run trough these checks and all good. Anymore suggestions? Do we need to wait for a fix for the app?
12 Aug 2021 03:44 PM
I don't have multiroom but I have Sky Go Extra as part of being with Sky VIP... and still cannot get my Q box to connect to my device??
Why would I be rewarded Sky Go Extra from Sky VIP if I don't have multi room ???
12 Aug 2021 04:16 PM
Posted by a Superuser, not a Sky employee. Find out moreYou don't need multiscreen to get Sky Go Extra via Sky VIP.
12 Aug 2021 04:42 PM
No, I was rewarded Sky Go Extra on Sky as a reward on Sky VIP, so yes I do in fact have Go Extra on my account.
12 Aug 2021 04:49 PM
Posted by a Superuser, not a Sky employee. Find out moreI was asking your "Why would I be rewarded Sky Go Extra from Sky VIP if I don't have multi room ???" question and was saying that Sky gives us Sky Go Extra as a VIP reward even if we don't have multiroom on our accounts.
13 Aug 2021 09:17 AM - last edited: 13 Aug 2021 09:19 AM
Posted by a Sky employee@Chris868686 Viewing your Sky Q recordings and channels from Sky Q in the home, you require Multiroom to do this. Sky Go Extra just gives you the ability to download content to your device, when you get Multiroom you also get Sky Go Extra but the 2 are not exclusive as you got Sky Q as a VIP customer, like yourself. Only having Multiroom is the requirement to view your Sky Q recording on your device when on the home network.
That is why the recordings button on Sky Go is not showing on your device.
Kenny
14 Aug 2021 05:51 PM
I was unable to connect Sky Go on an iMac to my Sky Q box when connected via WiFi to a Powerline Adapter and Extender. When I connected via WiFi direct to my Sky hub it connected to the Sy Q box immediately.
20 Aug 2021 12:04 AM
I have multi room with sky Q box etc. When I used to have sky broadband as well I was always able to watch the recordings from my sky q box on sky go. I switch internet to virgin and since then even though I can watch live tv and downloads etc it will not find the box to view the recordings. I have checked both settings and they are correct, turned my iPad and sky q box off and back on again with no luck. Can someone please help me
10 Sep 2021 10:21 AM
I have multiroom on sky q which is active and working but still can't connect to my Sky Q box from the sky go app. I've tried all the instructions and uninstall Ed and reinstalled numerous times but still doesn't work.
10 Sep 2021 01:14 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat is happening @jackismee1 ?
Any error messages and if so what does it say ?
10 Sep 2021 04:08 PM
@caesarome no error message. no tab at bottom of app to connect to sky q box. Only tabs available are home, tv guide, browse & downloads
