1
Discussion topic: Parental control
This message was authored by Laurynzena This message was authored by: Laurynzena
Parental control
I am trying to turn off the 'parental guide' but it's saying I can only use a credit card which I don't have? How else can I turn this off?
This message was authored by 63johnw This message was authored by: 63johnw Answer
Re: Parental control
Hi @Laurynzena  can you borrow a credit card ? Doesn't have to be yours. If not then the only other way is if you currently have a credit agreement with sky for a device you can phone up and that can be used to verify your age.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
Locked
Locked
